Cub question.
What are the holes on the right side of hood for on this little
cub?
I am presuming it is around a 56 and not a low boy?
Thanks in advance.
src=https://www.yesterdaystractors.com/cvphotos/cvphoto147926.jpg>
there was a brass rod to open the caps on the generator so you could oil it i have the rod that came with the 1947 cub i have
Really hard to tell.... Grills get swapped, throwing off an ID.... Look for casting codes on motor, transmission, torque tube, and final drives that will get you close.
Casting codes are in small tags, look like they are screwed on.
