David mains
New User
An old tractor mechanic,who worked on ford tractors as well as other tractors.he helped me overhaul my 641 ford workmaster.he ask me to go and buy a saftey valve,and went to toys auto parts,which had ford parts at the time.well they sold me a saftey valve.the FO-20 says to start the tractor and raise the lift then shut the tractor off and if the lift bleeds off at a constant rate then it's either the saftey valve or a leaking check valve.i ordered a saftey valve from you guys which is absolutely the correct part.apparently the old tractor mechanic used the wrong saftey valve and now here I am years later trying to figure things out.i still have your part they refunded my money,and I owe you guys 25 dollars.how can I repay for the part.
