JD 790 with 419 loader - points to grease?
I bought a used John Deere 790 tractor with the 419 front end loader. I need to service the tractor for the first time and while there are lots of YT videos on the fluids and filters I can not find anything with greasing it. Is there a reference of any kind showing me how many and the location of the points that I need to grease?
Thanks
(quoted from post at 11:13:46 08/22/22) I bought a used John Deere 790 tractor with the 419 front end loader. I need to service the tractor for the first time and while there are lots of YT videos on the fluids and filters I can not find anything with greasing it. Is there a reference of any kind showing me how many and the location of the points that I need to grease?
Thanks
With a bit of searching, you should be able to find the operator's manuals for both at https://techpubs.deere.com/
You can get free downloads or purchase manuals there. Click on Equipment publications to get to the manual search. You will likely need the serial numbers to find the right manuals (one for the tractor and one for the loader).
X2 what Jim stated. Operators manuals contain valuable info including lubrication points.
Most places for greasing should be pretty obvious as any place that moves probably has a grease fitting. Bucket pins cylinder pins and frame pins lift cylinder pins tie rods axle pivot axle knees if it has them and then front drive shaft slip joint and universals. 3pt linkage will be similar this will be most of them.
Jim, I was able to find the entire service manual on the link you provided, and want to thank you for it. It took me a couple tries
but I'm good to go.
(quoted from post at 22:30:16 08/22/22) Jim, I was able to find the entire service manual on the link you provided, and want to thank you for it. It took me a couple tries
but I'm good to go.
It is good if you purchased the service (technical) manual for more in depth diagnostics and repairs. The free downloads of the Operator's manuals will give you more of the info you need for greasing and maintenance normally done by owner/operators.
