Caburator help
to30man
I am working on my carburetor on farmall 130 and I have two pieces that I am not sure were they go. The little bullet piece fell out and the small spring I seen laying there and do not remember removing it. I looked at a few different diagrams online and do not see either piece. Does anyone know where they may go. Thanks
Key numbers 33 and 34, choke lever detent and spring.
They go, spring first, into a ''pocket'' in the carb lower body next to the choke shaft bore and face outward towards the lever permanently attached to the choke shaft.
I put the spring in first in the place
right above my brush but when I put the
choke assembly in it does not hold the
spring and little pin in they just fall
out. What am I not doing correctly
Does the rod and spring on the clutch
plate go over top of the shaft on the
upper side of the carburetor thanks
I would assemble it per the diagram in wore outs post.
It shows the choke plate with spring at the 6:00 position.
How the choke shaft aligns with this depends on where the flat is cut in the shaft.
You will have to look at the wear marks where the spring and ball rub against the choke shaft.
This post was edited by Rodney51Cub on 07/21/2022 at 05:38 am.
