While considering what I am going to do about the fuel filter,
I found this: There is a fuel return near the front of the tank
which I removed while cleaning the tank. The small-
diameter riser tube was there, but loose in the fitting.
Additionally, the return from the injectors has been joined to
the pump return, and this common tube is connected to the
side input of the brass fitting; the bottom of this fitting has
been brazed over.
Wondering if I can buy this fitting and restore these two
lines to the design positions; comments?
been brazed over.
