Neighbor wants to know what red to paint his '48 cub
andy r
My neighbor is ready to paint his 1948 Farmall Cub. I just told him to go to the International store and buy a gallon of IH red paint. This tractor is far from being anywhere near perfect. But, he thinks he wants to have some automotive paint mixed up so it will look just right. Is there a paint code for the red on his 1948 Farmall Cub???? Are paint codes specific to paint companies??? If so what would be a couple paint companies and their specific code for a red 1948 Farmall Cub. Thanks.
RUST-OLEUM I-H RED is as close to code 50 without custom mix i hav used it for years but i do sandblast then prime then sand and then paint let dry wet sand and another coat has stood up excellent over the yrs but they do have a shed but are used often
Did they have more than one version of red? Always thought IH 2150 red was the only one they used. Pick your favorite paint company and get their 2150. Should be good.
AaronSEIA
I've used RK IH red and rustoleum IH,
Buy a hardener and thinner.
I thin more with mineral spirits to get a smooth coat..
Gas reacts with paint. You Need to clear coat. Gas reacts with paint..
It would be IH 2150 red iff'in it were mine. I also use 2150 to paint my Fords it does not turn orange over time like Ford red does. I get it from CNH the paint is as good as you can get for the price.
Apparently IH 50 would be correct color till mid 49
Here is a Chrysler color supposedly close to IH50, PPG 70093/DuPont 7410.
Love rust oleum ih red
Working tractors, but sleep inside
Original Red was #50 but that changed to #2150 I think that was when they had to take the lead out of the mix. So far I like Rust-Oleum IH Red. It's a little darker which is the way I remember it looking as a kid.
Dave
He may change his mind about the automotive paint when he sees the price!
And unless he's properly prepped and primed, it will not appear or hold up any better than the off the shelf paint.
Preparation, application, hardener, and experience are all part of a good paint job. If he's looking for perfection he best seek professional help!
Rustoleum from a rattle can will fade EXTREMELY fast - after 3 years you'll wonder why you bothered. I sprayed some Rustoleum from their quart cans on a Farmall 350 and it looked great for years - but the
tractor was very lightly used in that period and spent a vast majority of its time in a shed. It never spent a night outside. At 10 years it still looked very nice. The last 10 years it has spent a lot of
time in hay fields and getting used a lot more. The panels sprayed with from the quart cans have faded a lot, but the rattle can spray areas are pink and going white.
I like the IH dealers 2150 paint. Cost about 50 bucks a gallon ten years ago.
Agree with the hardener. I consider it mandatory. Helps paint reach dust free state sooner. Helps with fading. And, really with gas spills. Hardened paint is much more resistance to that.
Not a fan of clears unless part of a system as I've seen several peel badly when the undercoat was not specifically designed for the clear used. Or, clear over a single stage that wasn't properly prepared or mismatched.
IH2150
My understanding its a modified synthetic enamel I use NAPA 5118 (martin Senour) hardner. Anywho that's the info I picked up on the Paint and resto board...
I also wrote down for the hardner 15128
Research shows it is an acrylic modified alkyd enamel containing UV inhibitors..
