I have what we believe is a 50's era COOP E4 Gas
REcently went to start and noticed that gas was on and leaking out the weep hole of the zenith carb. When gas shut off it bleeds back out the wing nut shut off of the gas just before the bowl. Is the gas not burned up in the line and pressuring back out or is this indication of needle or float problem?
When looking up answers to my questions I began researching serial numbers and found what I once assumed where serial number now learning are likely just parts stamped. I have numbers TG 9426 on left side of rear end, and numbers in 9000's on other locations. Left side of frame below distributor I see numbers 4C 34 26 (C is tough to see c,6,0???)
There's a metal plate on engine 6B230
What years the Tractor?
