Well hello again everyone!
I have taken the motor off of the tractor as everyone has suggested. I am one step away from taking the main bearing caps off.
In order to remove the crankshaft from the motor, I have to unbolt the connecting rods.. right? I have one piston almost top dead center that I cant get to. Should I just take the bearing caps off and try to tap the piston (likely frozen) down until I can get to the bolt? What about the other two pistons which I have the bolts off of (probably also frozen?
If anyone wants / needs a picture to better explain, just ask.
