1939farmall
I posted about bringing this little tractor home last week. Today
we started looking it over.
I had some things to do in the shop so son went out and started
cleaning some of the gunk off of it. Hes pretty excited to work
on it!
This is an Oman B48M engine we our working with. The story
we have is that it ran when parked, and its been sitting for 10
years. The first thing we noticed is a missing air cleaner screw
right by the throat of the carburetor. Fortunately it appears to
just be missing and didnt make it into the engine. I see a lot of
corrosion on the butterfly in the carb so Im figuring on getting a
gasket set and opening it up. Im sure it needs cleaned.
Son got the air filter off while I took the plugs out.
Heres a picture of them. If you can read plugs please tell me
what there saying!
This has the usual funky wiring a lot of old forgotten machines
end up with. Its also missing the battery ground cable for some
reason. If we can get it running it will get a rewire for sure. It
needs a set of points as well. The engine doesnt appear to have
much compression so we have the cylinders filled with ATF for
now I can see the intake valves moving and the engine turns
free so Im hoping it just has some sticky rings. The carburetor
bolts run up from the bottom of the intake so it was easier to
take the intake and carburetor of as a unit. We found 1 intake
gasket was missing as well. Thats where we stand on day one.
Pretty typical items so far for a machine that has been sitting for
years. On the plus side the gas tank look pretty clean with just
some rusty loose stuff in the bottom, someone added an
electric fuel pump and it still works! And the engine oil and
hydraulic oil look surprisingly good. If you have any tips tricks
thoughts or ideas wed love to hear them. Thanks!
on it!
what there saying!
