rlp in Co.
Well, I think maybe the computer went bad. The problem is when you floor the gas pedal, the engine goes full power and then nothing over and over. I first thought it was starving for gas but I checked and it pumps a couple of cups in only seconds. The pressure is at 45 pounds even when the motor cuts out. The voltage to the coil is good even when it cuts out. The signal from the distributor is good even when it cuts out. The voltage on an injector goes to zero when it cuts out! So I think it's the computer right? I unhooked the knock sensor and the oxygen sensor and it made no difference.There are three vacume lines going to the intake plenum that I don't know what they do. Any suggestions?
