There is a pull switch that under a normal operation, pull out is on. With a magneto, out grounds the magneto, Correct? The switch appears to need to be replaced. It looks bent.
The switch has a wire that goes to the magneto. I wanted to be sure that the wire was tight on the stud. It was, but the stud is loose in the magneto. Is the stud just connected to the case of the magneto, or is there a wire inside the magneto that I will need to verify is attached to the stud?
TY
SDE
TY
SDE
