Big snap rings and a few other things
SVcummins
About got the 4020 back together resealed the pto rear shaft
replaced the bearing and bearing quill the old bearing has
quite a knock to it spinning it by hand . Also started
resurrection on the ihc 314 plow
It did a couple times its so big it couldnt fly to far then I decided I needed another hand but where could I find one
Good idea with the vice grip to hold the snap ring. This keeps you from digging through years of stiff under your bench looking for that flying snap ring. Then find it on top of your bench. The small flying parts are harder to find. Been there. Stan
Tore her all to pieces in the rocks . Had a bent trip beam when I got it going to pick one up today need fo weld the gauge wheel back together . Little plow has made me a lot of money over the years the only thing I dont like it doesnt have much trash clearance and it makes a mess trying to do the head lands in heavy sod
I learned a long time ago to listen to where it lands not try to see where it flies and you will probably find it .
