Hello, We have an issue with our Ford 4610. Motor cannot turn by the crank bolt but it can turn slowly with great effort with a pry-bar on the flywheel teeth. Oil pan was dropped and there was no indication of engine damage, the crankshaft had thrust play and connecting rods had normal endplay. All gears appear to be normal. No damage to the valve train. I wasn't present when it locked up, but the person who was said they heard a strange banging noise out of nowhere and they shut it down. Afterward the starter could not turn the engine. I was able to see the clutch fork engage the throwout bearing but the motor still can't turn easily when clutch is pushed down. I'm thinking there might be something stuck in the flywheel area. I heard that "headland" pistons would come apart but I don't see any indication of damage on the cylinder walls or pistons when looking up from the bottom of the engine. Anyone had an issue like this with these 3 cylinder diesels? Thanks
