8n hydralics
First off clutch engaged say pedal is up disengaged pedal down
Pull the right side inspection plate and have the lift control in the up position with it running. Look for oil movement or dripping and that is where the problem is. Good chance the cylinder piston rings are bad. Best to replace with the new improved NAA type piston and o-ring
