I installed a flange bearing on my flail mower blade drum a few months ago. Right away it didn't take grease. the problem was the bearing hole didn't align up with the bearing housing. I found out when I removed it. It is a four bolt 17/8 shaft size. The shaft turns very fast. With some time now, I know it hasn't taken grease. I changed it. When I removed it the bearing was still good, with the grease from when it was made. I may be over greasing my bearings. I give them a shot every few days. I guess I should back off the greasing. No manual is available, and never will be. The company is out of business. Any thoughts? Stan
