Fan belt replacement - grease recommendation
Hi All,
Changed ye olde fan belt on the Farmall M and want to grease up the threaded collar to ensure easy on/off and future adjustment.
What do you recommend?
The threaded collar? The sheave? I didn't grease mine on my 400 when I had one. Just wire wheeled it nice & clean. Do the same to the set screw. No problem then. Wouldn't want to risk grease oozing onto the belt either. Less chance of slippage & there's a good many times that rubber & petroleum products don't get along well. Unless you found a belt that requires grease? I'd recommend that you don't forget to grease the muffler bearings while you're at it. ;v)
Mike
Put this on the threads, it will keep them operational for several years, and if repeated every 5 or so will make it easy to change the belt. Remember the belt is to be 1 inch loose when pushed hard !!! Very important to keep the water pump bearings alive. Jim
Silver Goo (molybdenum Disulfide)mwill work, I forgot to attach LPS corrosion inhibitor in my post below. Jim
Hi Jim,
1 inch deflection when pushed hard - got it.
What deflection would you recommend for an installed alternator?
Think right now I have 1/2 inch deflection with what I would call medium pressure.
(quoted from post at 17:37:54 08/21/20) Hi Jim,
That sounds about right. It should show it in the operators manual.
While anti seize is good stuff it's like nnalert, starts out with a little dab here and by the end of the day i'm finding it on everything everywhere.
(quoted from post at 12:26:54 08/21/20)
then you are using way too much of it..
once assembled, wipe off any excess seen and you wont have that problem anymore.
