I have a ford 3500 loader with backhoe on it, is there a way to
turn up what pressure the relief valve opens? Tractor has a
new pump that?s ran off crank. feed goes to the hoe first then.
from the hoe controls it returns to the loader control valves
. witch feed it, then back into the tank. I believe the relief valve
is opening to easy. If the front tires sink in the ground some
the back hoe can not push the tractor back while digging it
does even put any strain on engine trying, to push it with hoe
like other hoes I have used when trying to ask more then they
could do. it also won?t lift the front tires with loader most of the
time. The loader controls leak when using it but lifts full
buckets no problem. But won?t lift front end most of the time
will some times. The back hoe can pull it?s self backwards
with ease, I guess that because there?s more piston surface
on the pull side of cylinder. Idk any ideals?
