Stephen Newell
I had a thread a couple days ago about my case 210B tractor how the starter was struggling to turn the engine over. I replaced the battery and ran an auxiliary ground wire to the starter. I made sure there was no gas or water in the cylinders and it still struggled.
I may have found the issue. Someone suggested I might have a stuck valve so I took the valve cover off, removed a spark plug and cranked the engine to see if all the valves were functioning. They were but I noticed one of the exhaust valves had a broken spring.
I've got a replacement spring ordered. Now I have to figure out how to get the snap ring off the valve. There is only about a sixteenth gap between the ends of the ring.
