Keith Molden
Got it back Friday morning and checked everything over-looked good except for the engine oil which was low. I pretty much thought it should have been changed since they removed the intake, but it was what it was. Added oil to just below the full mark. Saturday tedded about 4 acres with it. Sunday morning checked the oil and it was showing over full by a little, thought I must have overfilled it and it hadn't ran down completely when I had checked it. Baled 28 bales with it Sunday and it is showing between 3/8 and 1/2 " above the full mark. So I do believe there is an injector line loose or an injector o ring causing the problem. The injectors are under the intake. It goes back in the morning when they come and pick it up. Keith
