Safe enough ??
wolfman
To help hay from dragging under the tractor I'm using a grade 8 short bolt instead of a drawbar pin. It is a stout bolt, probably 7/8 in. Today baling a steep field I wondered if the bolt was as strong as a same-sized hitch pin.
I use bolts in both discbine and baler. Have for years, never an issue, keeps from making bunches and dragging like you said.
Likely harder. We used them all the time in the clevis for plowing with pull type plows, hitch pins wouldn't hold up. Never had an issue with a bolt.
(quoted from post at 21:18:41 07/29/19) Likely harder. We used them all the time in the clevis for plowing with pull type plows, hitch pins wouldn't hold up. Never had an issue with a bolt.
"Tougher" would be a better trait to hope for.
"Hard" isn't always a good thing, "hard" things break.
Dad bought a Vermeer 605C new in the late 70's and that was the pin that came from the factory with it. When I say from the factory I mean that literally. Mom and Dad went to Pella and towed it home like 175 miles.
jt
I dont know the price difference between hitch pins and bolts, but I bought a couple short hitch pins at the farm store for exactly that purpose (haybine and baler).
The manuals for most balers and other hay machines say run the pin up through the bottom instead of down through . The manual for my 855 even shows how to make one using a bolt a nut and drill a hole through the bolt for a cotter key . In really heavy hay the hitch will sometimes still cause problems so then the rubber flap comes in handy
There is little information on the bending resistance of bolts because bolts should not be placed in a position where the force applied is perpendicular to the axis of the bolt and off set from the bolts supported length (IE. sticking out between surfaces like in a hitch pin that is loose between two plates. To publish a description of strength when the bolt is used improperly would be a legal mistake.
With that said, and with the lack of published data. I took a new 6 inch X 3/8 grade 8 bolt and bent it in a 6 inch Wilton vice by hammering it sideways, with no heat. The bend produced tiny marks from the vice jaws where the bolt stuck out see image, and full hard swings from the 2 pound hammer. A similar 3/8 grade 5 bolt had much larger marks, and less than 1/2 the swings. (I do not have the other bolt, it was scrapped)
As can be seen, the bend radius is about a bolt diameter. There is no cracking or surface appearance change on the tensile side.
I hereby say grade 8 is as good as it gets for a hitch pin. Jim
A old rubber mud flap clamped to the drawbar with some angle iron is best.
Used to bale a neighbors hay, some of the fields were rough with hills and drainages, heading down one of the steeper hills one day I heard a odd noise and looked back to see the baler up against the tractor with the tongue burying itself into the ground.
The clip had broke allowing the pin to drop out, luckily I shut the pto off before it snapped the pto shaft off the tractor.
Had it came loose going up that hill the baler probably would have ended up upside down in a gully about 200 ft down the hill.
I'll never install a hitch pin upside down again and expect a clip to hold it up.
