caterpillar guy
Fling Belgian you mentioned having a Cat. Is this one of the newer rubber track machines? And if so have you had a problem with it wanting to just go in a circle if it is wet and stuck?
We had a local guy tell about them doing that when in wet ground and stuck or at least making tracks. Not just sure what he was talking about. Our old steel tracked Cat's if one track was on better going than the other would spin the track so it would go off true. We just either pulled the opposite steering lever or lightened the load till we got through the wet spot.
