BuckeyeFanInFL76
I recently bought a 1983 IMT 539 tractor. I have liked it so far and glad that I have bought it. However, I noticed fluid leaking out of the back where the PTO shaft is located. I have a question regarding fixing these types of leaks. Is it safe to assume it needs a new o-ring on the seal bushing? That is what I am thinking but I guess I will not know until I remove the shaft. Also, are there any other gaskets, seals, etc...that would be best to replace or typically fail, while I have the PTO shaft removed?
This is the first time I have worked on a PTO shaft. I see there is a seal on the seal bushing, do these fail regularly?
Thanks,
Jarrod
Thanks,
Jarrod
