Another battery question
grandpa Love
Battery out of Allis 5030 is shot. 24 hours on slow charge, will slowly turn tractor over. Not enough juice to start it. Took the new 12 volt out of Dave's Oliver. Allis fired right up. Now new issue. 12 volt battery in Ford 960 won't hold a charge. When I took it out of tractor the positive post is loose. Moves up and down about 1/2 inch. I'm guessing that battery is no good?
Yep, sounds like toast to me. How old are these batteries? The one with the loose post, either someone torqued on it too much or it had a mfg defect, or both. Now you have a couple of batteries to trade in.
I have a battery on the bench as well that won't hold a charge. I charge it and a couple days later it is at 8 volts. But, it is an old battery.
Paul
if your battery cable was loose at all it might be creating a small arch. that happened on my 960 as I took the cable off but somehow it fell back on top of post. hence battery went dead but I caught it quick enough that I put it on a bat maintainer for slow charge. been 4 years ago. still going strong
I buy the interstate rebuilt batteries, any size you want is 40 bucks with a 1 year warranty, been buying them a few years now, run them on everything except my Wifes vehicle.
Post broke away from Bush bar internally. You are not only missing a cell because of the brake you also have a potential explosion when it arcs over. Get RID of it. Please!
So do I. If you know where the warehouse is they are a great deal. Mechanics donot want to screw around after they put in a new altinator and just change out the battery to cover all of the bases. I picked up two just a few weeks ago. My new digital battery tester just purred when I tested them! Yaaaa!
Batteries fail, and are a "cost of doing business".
Best to wear eye and face protection when working with them.
Gonna GUESS you've never witnessed a battery explosion, or you would not have been wiggling a loose battery post.
Can a discharged battery damage the alternator? - Answers
www.answers.com ? ? ? Car Electronics and Lights ? Alternators
It can cause sudden alternator death. There is a paper that comes with many rebuilt alternators that recommends always charging a dead battery before running the vehicle to prevent sudden alternator death.. Good advice. The alternator will have to work very hard until the battery is charged fully.
I damaged 3 alternators this way. Thank God Auto Zone replaced them, lifetime warranty. Later, I discovered I had a parasitic load draining the battery. A few miles down the road and I smelled a toasted alternator, then battery light came on.
This is why I'll never jump start my vehicle with a dead battery. I charge mine first.
24 hours may not be enough depending on the state of the battery and the Amp Hour rating of the charger. A 1.5 Ah charger would only recharge 36 Amps at that rate. A 770CCA battery would likely require much more juice to recover from a "dead" state.
HTH
Aaron
No idea what the weather is like where you are but if it is below freezing and the battery was run down you will not get it to take a proper charge until it is thawed out first.
Just because you can see some liquid under the caps it does not mean there is not ice lower down.
Bring it in to a warm place for 2-3 days then try charging it, I have revived countless batteries this way and it works 80% of the time.
The one with the loose post, get rid of it.
Hooking it back up or trying to charge it is a big bang waiting to happen.
Central AL. Couple nights below
freezing lately but warm days.
Battery was bought in 2011. I'm
good buying a new one!
