I bought a Deutz 4507 with worn out lower thrust surfaces on the front knuckle. The axle only had simple washers for a thrust bearing.There will probably be 1/2 inch of clearance after I have it resurfaced. Not having a bearing might be part of the reason these tractors were know to break the steering arm when using a loader. The king pin is 35 mm diameter.
Need some bearing ideas and numbers that might fit. I guess I could always go back to some washers. This is an Italian built Sige 3500 axle.
