(quoted from post at 18:43:20 02/03/19) I have to ask Bob, my main box has a Main or Master switch which disconnects me from the Power Line. I have only tested it once to see if I could run the well. I plug into my garage welder outlet with the generator, and of course make sure the Main switch is open. Is there an issue or safety issue with that I am missing?
Paul
(quoted from post at 20:29:17 02/03/19)
Bob, I understand if you feed power into the grid a lineman etc. can get hurt. I understand how easy it is to forget to do something. I do it from time to time with my coffee maker - forget to empty the carafe which means coffee over flows and floods the counter.
My question is; how can you back feed the grid with a small generator and an extension cord? When the power goes off I leave my breaker on and I suspect everyone else without a generator does likewise. It seems like your little generator would be powering all the neighbors houses...? Just trying to understand what is actually powered.
(quoted from post at 19:30:11 02/03/19) Didn't want to hijack the "generator" thread.
It simply amazes me how many guys thing "backfeeding" power to the house during a power outage is OK, and brag about it on a public Forum.
Dang Bob, you kind of just jumped out there bashing everyone without having all the facts. How do you know they are not doing it the correct way.
And by the way I used to be a lineman so I know the dangers, but give people a chance before bashing.
(quoted from post at 05:13:54 02/04/19) I use a check list, with three buildings I have to do allot of breaker flipping in order to not overload the generator. The way the elect is distributed between the buildings makes it really difficult to install a lockout or transfer switch.
I would bet backfeeds happen because the guy is an idiot. Probably the same guy that runs the generator in his attached garage or worse yet in the house.
Nobody is entitled to an opinion that would put others (especially linemen) at risk.Either way, it's a statement of opinion and last I checked, he's entitled to it.
(quoted from post at 19:47:27 02/03/19) VicS and Modirt were the [b:1f8687a092]two dangers to society[/b:1f8687a092] on the first post .
Sad thing is that no matter who or how many times back feeding is expiate dot be dangerous. The more likely they are to backed, just to prove that they can. Nor do they understand electricity or the law to comprehend how dangerous they are.
(quoted from post at 19:10:28 02/03/19) [b:b7efecc8a9]Problem is cutting the main only breaks the two 120 volt lines coming in. The neutral that carries voltage back to the transformer is still hooked up and carrying current from the generator to the transformer. [/b:b7efecc8a9]
I did mine differently. I installed a twist lock generator plug in on the basement wall. Panel box inside with circuit breakers hard wired to two 20 amp recepticals for the freezer and refrigerator. I use a power strip surge protector for the refrigerator, TV,etc. I am planning on running another line and add a plug for the well pump. The generator isn't tied into the grid in any way.
(quoted from post at 10:31:42 02/04/19)(quoted from post at 19:10:28 02/03/19) [b:61f59581b3]Problem is cutting the main only breaks the two 120 volt lines coming in. The neutral that carries voltage back to the transformer is still hooked up and carrying current from the generator to the transformer. [/b:61f59581b3]
Someone mentioned this to me a few weeks back. Claimed that cutting the mains still allowed generator power to backfeed through the neutral bar.
So then I see this guy.......who by the way isn't some piker......that is a Reliance Control video.
https://www.youtube.com/watch?v=TKruj9BpZM8
Hasn't he just done the same thing?
(quoted from post at 12:24:51 02/04/19)(quoted from post at 10:31:42 02/04/19)(quoted from post at 19:10:28 02/03/19) [b:b24045c193]Problem is cutting the main only breaks the two 120 volt lines coming in. The neutral that carries voltage back to the transformer is still hooked up and carrying current from the generator to the transformer. [/b:b24045c193]
Maybe remotely possible if there was problems if there were no ground bond anywhere to the neutral . It is a “ what if” that is too small of a possibility to worry about.
The topic was raised one time with a “what if” question and has inadvertently grown into an “ issue”.
The transfer switch for a floating neutral generator does not switch the neutral . The transfer switch for a bonded neutral generator is supposed to switch the neutral .
The reason being is to avoid flowing neutral current through the ground system .
(quoted from post at 07:27:48 02/04/19)
I had the same question I think you are asking. Just curious about what all is energized when someone backfeeds without a proper disconnect. Just the lines? Neighboring houses?
When power goes out at my house I leave everything "on" until the power is restored. If a neighbor backfeeds will that harm/energize my house? Should I flip my main breaker just to protect myself? (But how do I know when power comes back?)
Just to clarify: I do not even own a generator. When the power goes out the place goes dark. I have propane heat that doesn't require electricity, and a way to easily hook up the hand pump for water in the laundry room. A propane stove to cook on. Books to read by oil lamps. So I do not and cannot backfeed, just wondering how it all works.
(quoted from post at 15:27:48 02/04/19)
(quoted from post at 12:59:42 02/04/19)(quoted from post at 07:27:48 02/04/19)
Whatever is connected is energized. Depends on how much damage the storm did to the lines.
Electricity doesn't flow just one way. It can go "in" any hole and come "out" any hole. That's how backfeeding works. Instead of the electricity coming in through those wires from the road, it is coming in through one of the electrical sockets in your house, courtesy of a generator and a "suicide cord," which is an extension cord with two male pronged ends.
The problem is that unless you disconnect them, the wires from the road become a new "out" hole. They go to a transformer which normally reduces the voltage from the overhead wires down to the 240V for your house. When those wires from your house become the new "out" hole, the transformer works in reverse, changing the household voltage back to high overhead wire voltage.
It only takes a fraction of an Amp to kill someone. Our bodies have very high resistance which is why people often survive contact with household voltage. However, the voltage on those overhead wires is so high that even with a wimpy little generator, that fraction of an Amp can flow through a human body to kill a person.
Ideally there are enough other transformers and houses connected to the lines to overload a backfeeding generator and shut it down, but there are circumstances where there isn't any other load on the wires, leaving them live and deadly while the backfeeder sits in their house watching TV, not realizing there's a problem.
We had an outage last year in my neighborhood, where I live there are lots of houses, with several connected to each transformer. Someone up the street was backfeeding their house with a generator. I heard the BANG when the linesmen grounded out the line. So even though there should have been several houses killing that generator, it was working just fine.
I agree, you don't want the mains on if you're backfeeding a genny for your place. Near as I can tell that's what the transfer switches do- open the mains. I'm still trying to figure how backfeeding with the mains open can be a hazard though. an open circuit is open, right?
Exactly. The world's most reliable person will still make a mistake if the hardware makes that mistake possible.(quoted from post at 15:04:27 02/04/19)
And in the case of VicS, he did mention that he had tripped both his main at the meter and his main on the service panel. Technically, that would seem to solve the backfeed issue, provided you actually do it. But folks are human and that means prone to error and considering what is at stake, I can now see the need for a system that takes error out of it. In theory at least.
(quoted from post at 21:36:12 02/04/19) [b:526c9a1230]I have seen main breakers that were bad and did not actually break the connection. [/b:526c9a1230]I changed out a service one time on a house. I had permission on the utility company to pull the meter to do this. When I installed the meter it immediately started turning. I knew the main breaker was off. Wound up having to change the main breaker.
(quoted from post at 09:31:47 02/05/19)(quoted from post at 21:36:12 02/04/19) [b:0254db7f6d]I have seen main breakers that were bad and did not actually break the connection. [/b:0254db7f6d]I changed out a service one time on a house. I had permission on the utility company to pull the meter to do this. When I installed the meter it immediately started turning. I knew the main breaker was off. Wound up having to change the main breaker.
My first thought when reading this was it was a valid point, but unless it could be shown that the generator was the cause of the failure, it would not apply here. Otherwise, if the concern is that breakers can go bad, then that invalidates the use of breakers in general. As much of a danger to anyone working inside the panel as it would be to a lineman upstream. And that would also preclude the NEC approved use of the sliding lockout switches.
But that also raises another question I don't know the answer to but I'm sure someone on here does.........in the event of a power failure, the digital meter should go dark. If you are somehow backfeeding when the generator is running will the meter light up and start running backwards? If so, would that not be a good test to double check your transfer switch / lockout system?
(quoted from post at 09:36:01 02/05/19)
And this raises yet another question, if you have a big solar array or wind generator and you are plugged into the power grid, what safety measures are there to cut that off to prevent backfeeding when the power grid goes off?
(reply to post at 11:27:06 02/05/19)
Jeremy, in order to know when the power is back you just install a power back indicator. It sits on top of or near your panel and works by induction to sound an alert.
(quoted from post at 05:49:15 02/04/19)
Home many electrical services/electrical meters supplying the buildings ? What size of generator ?
Why not use this or a similar transfer panel . Any size of generator can be connected . https://www.homedepot.com/p/Reliance-Controls-200-Amp-Outdoor-Transfer-Panel-TWB2006DR/202216488
http://www.reliancecontrols.com/ProductDetail.aspx?TWB2012DR
(quoted from post at 12:23:15 02/05/19)(quoted from post at 05:49:15 02/04/19)
Question B&D.
From looking at the images for the links you posted, it looks like this is basically a "bracket" that fits over the main breaker and one below it, presumably for the generator circuit, so that when you slide it it turns the main off and the generator breaker on. Is this correct?
-Scott
(quoted from post at 09:20:29 02/05/19)(reply to post at 11:27:06 02/05/19)
Showcrop:
Never heard of such a device before. I learn something new every day.
Any risk to my stuff if I just leave it all alone and let the power come on when it does? (Which is what I've usually done.)
(quoted from post at 09:23:15 02/05/19)(quoted from post at 05:49:15 02/04/19)
Question B&D.
-Scott
(quoted from post at 22:00:46 02/05/19) I’m struggling to understand how that little interlock bracket is worth upwards of $300.....
-Scott
(quoted from post at 19:00:46 02/05/19) I’m struggling to understand how that little interlock bracket is worth upwards of $300.....
-Scott
