I will preface this post by saying I know that using the OE hydraulics on my Ford 3000 to power the loader will be slow. Before I get into buying another pump, I just want to mount it to the tractor and make sure everything works as it should and I wanted to see if what I'm thinking is correct.
We have a later model 3000 where I work with a Bush Hog 2425QT on it. It is plumbed up with this adapter plate installed between the cover and the standard block-off plate.
These two hoses are all that are connected between the joystick valve and the tractor. There are only two ports on the adapter which I'm sure came with the loader. As it is hooked up, the loader and the 3pt both work.
So, here's a basic diagram of how I'm thinking to hook it up.
My question is the Power-Beyond. I'm not exactly sure I understand how it works.
Thanks.
-Scott
Thanks.
-Scott
