CO-OP 1940 B-2
rwstipe
New User
Anyone know where I can find carburetor parts for the CO-OP Tractors? Are they under another tractor MFG?
Co-Op did not build the engine. You start by finding out what engine you have then identify the carburetor , sometime there will be a small tag attached. After that goggle or NAPA is your friend or maybe the oldest shop you can mind in you town.
My initial research seems to show you have a Chrysler engine with a Zenith carburetor, again a good NAPA man is going to be your best bet.
Your right. Chrysler engine & all I have found have Zenith Carbs, Mine has Bendix. Will follow through with engine searches.
Thanks. This is a lot of fun getting these old irons back on the road again.
Weldor ...... Later on after 1946 or so, some of those Canadian buillt Cockshutts (30, 40, and 50 modes) were badged as Coop E3, E4, and E5's. This 1940 version in this post was a whole different tractor built by someone else. See the link below ...
Untitled URL Link
Must be pretty close to the same. Co-op went out of Mfg & Cockshutt took over.
Thanks for the feedback
(quoted from post at 20:46:47 11/27/18)
I think Zenith and Bendix are the same company. Or maybe one was a division of the other?
Here's some more info on the Co-op name as it appeared on some different tractors. When Cockshutt (Canadian manufacturer)
eventually used the name on their model 30's, 40's, and 50's, I don't think there were any corporate takeovers or affiliations
with the earlier Co-ops. The link below has a little slide show, one of which I think is the model in this post made by Mr.
Stipe.
Co Op tractor history information
