Manifold bolts
jdr1943
I need help in finding manifold bolts for a 464 IH gas they are 3/8x1/38x16 they are copper IH has them for $29.00 ea.i tried finding them but my puter skills are limited I will use grade 5 if I can't find anything else.
Here is a site I use all of the time to buy bolts. Bolt Depot.
Here are Silicon Bronze bolts. I believe these would be what you need. As pure brass bolts would not have much strength. 3/8 x 1 1/2 are $2.17 each.
https://www.boltdepot.com/Tap_bolts_Silicon_bronze_3_8-16.aspx
I found some silicone bronze for 2.17 on this website, they would probably be better than steel. If you use gr 5 steel put some anti-seize on them. We used to use some beryllium bolts in one place where there was a concern about them galling, I think that's a copper alloy.
http://copperstate.com/shop/983/hex-head-cap-screws-silicon
There are lot's of copper alloy bolts available, just google them.
With all that advice given, I would torque them to 27/32 ftlbs ,and in a W pattern. Warm the motor up,let her cool off and retorque. CM
Do you know any electricians that do commercial work?
Many buss bar connectors and ground lugs had 3/8 copper bolts.
