CIH Magnum 71 Series Dash Bulb
connor9988
Location
Central Iowa
What type of bulb do I need to replace the dash flasher/turn signal bulbs? The right side has burned out and I would like to replace it. Also, do I just remove the 4 screws from the dash plate and carefully
lean it out to change the bulbs? Finally, is there an LED equivalent that I can put in for longer life? Thanks!
From MY experiance. Most bulbs in dashboard sockets are 194 bulbs. There are LED replacements and if you go on Ebay you can even buy kits with every LED you need with all of the correct colors too. Some car systems work with every bulb except the flashers. They just will not flash. My Ford Explorer wouldn't. Here are the two pictures that show them.
It is rare for a signal lamp to burn out.
It happens, just not common.
If a new lamp doesn't fix it, look the circuit board over, check the grounds, the socket, etc.
