Got another one
Nick167
Picked up this Farmall BN today from a neighbor runs really good but seems to be over charging the battery and the switch that controls the lights and charging rate doesn't seem to be working either. Is there a separate oil check for the belt pulley and power take off? Thank you!
I thought the N designated a single front wheel,it must have been changed at some point in its lifetime.
'N' designated the rearend housing. 8" narrower than a regular B. Each could be had with either front. single is more common in the furrow irrigated areas.
Belt pulley and pto get oiled from the transmission so no seperate level check. You could take out the pipe plug under the belt pulley gearbox to make sure it is getting oil from the tranny. A cup or so of oil should come out. Run the tractor for a few minutes to refill that gearbox before running the pto or refill thru plug on top of that gearbox.
You'll need the wiring diagram/service manual to fix the charging and light switch problems or post specific questions here.
Nice tractor.
Dave
