Hello, I have a gear pump that drives my front loader and backhoe on my 1957 MM 445I, but not at the same time. The tractor was born the pump, I have put in new needle bearings.
In order for me to get max power I have to throttle all the way up. If I am picking up a roundbale at half speed it will not do it, I have go wide open. Is this normal?
I though that running at high RPM would only change the flow rate (GPM) and the pressure (PSI).
Can somebody set me straight? I have been thinking about this for a while and since I have been home sick for 2 days I figured I would use the time wisely....
Thanks
Zeek
Thanks
Zeek
