I need to cut out bad sections and weld in newer, cleaner metal. the fender skins rusted thru where dirt got between the skins and the fender frames. Is grinding away the rust at the edges of the cuts enough, or should I treat the metal with Ospho and then grind the edges?
My welds are to high and I want them to be lower to reduce the grinding effort. What do I need to change to do a better job. Move faster seems obvious. My wire feed welder had a hole in it and I wasn't getting enough gas to the metal surface. Now that I have replaced it, I hope I can do a better job of welding.
TY
SDE
TY
SDE
