PP
I have a 60 John Deere didn't use the hydaulics at all till I bought a loader. My issue is the powertrol is leaking between the couplers and the body at both the top and bottom couplers. What is the fix here? Thanks
There are two O-rings for each plug in the body of the powertrol unit. The one furthest into the powertrol is a little tedious to replace, but it's do-able.
Ok I had the couplers out and looked in the body guess I missed seeing the o rings do you happen to know the part number?
One of the O-rings (in each hole) is easy to do. The other one is pretty far back in there. You can remove the pipe plugs on the right hand side of the powertrol and work from both sides, so to speak. The repair manual suggests a little home made tool to help you nudge it in place, but I've put several in using what I have in my tool box. Here's a copy of the page from the repair manual.
That's pretty hard to read. Let me know if you want to try e-mail or snail mail.
