schmitz777
New User
Alright I have a fairly stupid question. Using this tractor I was able to plg in the hydraulics in the rear using pioneer plugs. Just pushed right in and they would lock. Now somehow they are pushed in and I cannot pull them back out. What's the trick? I turned the tractor off, moved the levelers back and forth, even tried to pull the collar back with my finger cant get it to pop back.notice the one on the left versus the right.
I thought the lever turned itself as you pull it out. Them old JD valves can really be a bit-h to pull out sometimes. Been a long time since I had one put I seam to recall you sometimes have to use a pry bar to push the spool from back.
This sometimes happens on my 1520 JD. I can push it with my finger from behind and it will pop back out to the correct position.
Unless someone updated that tractor to ISO/pioneer couplers it would have came with the JD tapered style coupler barrels. So I am not sure what you have or what you have done. LOL
Tried prying no luck. When I stuck the hammer inside the hydraulic post I think I may have damaged the gasket now. Still stuck forward really running out of options I may have to just bring it in. Which is sad because I'm sure there is something I just can figure out here
