Loren in Iowa
I need to solder a float arm onto a two inch diameter brass float. My soldering experience
is VERY limited. First, I need to unsolder an old bracket off the brass float. I don't want
to disturb the soldered seam around the two halves of the float. Is this best done with an
electric solder gun, or a Berz-o-matic torch? Which should I use to solder the new arm onto
the float? I'm replacing the cork float in a Farmall Regular carburetor, with a brass
Briggs and Stratton float.
