Just wondering how you guys go about changing coolant on the newer tractors. Older tractors have drain valves in the block and rad but on
mine which is a NH 7635 I don't see a drain on either. The last time coolant was changed was when the rad was worked on which was a decade
ago. Seeing as the tractor has to last for a long time yet, it is high time for another change. I was thinking to pull the lower rad hose
off the bottom of the rad but is that enough to get a complete drain of the block?
