moving shelter
pic might work
cant figure out the video. I have 2 chains at the back going to the corners. So it is actually being pulled. 2 chains go out from the loader to each side , and 1 chain down to the cross pipe to lift. I had to move it around a couple of tight corners and it worked real well. Both ends are to be built shut yet with man door in each end. My plan is to build a man door into the large door on the one end.
I moved our wood shed with our JD 4600 in a similar fashion! Put a big timber across just behind the balance point, put the forks under it and then tied the back down to the ROPS, picked it up and drove away.
I sold Hi-Qual fabric buiding years ago. Our portable line was setup to be moved from one spot to another. They had a 3" tube frame all the way around them .There were drawings and direrctions in the owners manual on how to move them. It got us around some building code issues in certain areas because of it being portable.
