hurican question
no not the rain. it draws the water by evaporation. So leaves the salt behind also why warm water strengthens the Hurricane.
"Tiny parcels of salt can sometimes mix with rain causing rain to become somewhat salty". Quote from linked article in Chicago Tribune.
A hurricane is in fact a type of heat engine. It transfers heat between a warm body (ocean) and a cooler body (atmosphere). Part of the heat is used to do work, e.g. move air. It operates on the same thermodynamic principles as an internal or external combustion engine. The amount of work it can skim off from the heat transfer is a function of the ratio of the the temperatures between the hot and cold bodies. The smaller that ratio (cold temp divided by hot temp), the more work it can do. Also it is impossible for all of the heat that is transferred to be converted to work, a form of the second law of thermodynamics. By the way, this was all figured out in the 19th century by French scientist Sadie Carnot.
living on Long Island I have been thru many many hurricanes---they have salt rain and leave a salt residue on vegetation,buildings and vehicles--some times so bad that it kills the leaves,plants and bushes,but most will come back the next year
(quoted from post at 10:30:54 09/13/18) If all that energy comes from warm water, how cold does the water get?
That's a good question. But given the massive size of the ocean and convection, I'd guess the temperature drop is small and brief but measurable if you could be in the right place at the right time. Under the right conditions, a hurricane should leave a wake of cooler water behind it.
I think what you are experiencing is wind-blown surf. If you go far from the ocean, the rain from the hurricane should not be salty for the reason given above (salt does not evaporate).
The rain will have salt in it. Look at cars from Florida's coast and you will find they rust around the drip rails and such. I have bought farm equipment from the piedmont region and it will have salt corrosion on it if it set out side.
(quoted from post at 15:27:22 09/13/18) The rain will have salt in it. Look at cars from Florida's coast and you will find they rust around the drip rails and such. I have bought farm equipment from the piedmont region and it will have salt corrosion on it if it set out side.
That happens 24/7/365 from surf action.
But canes DO pick up salt water and it comes back down as rain.
Not enough concentration in the rain do be physically noticeable but it does happen.
The eye is like a tornado and will suck up ocean water from the white caps.
I joke that I heard when I was a kid but it doesn?t work anymore == Why do they always name hurricanes after girls? Have you ever heard of a himmicane?
It must since the salt is in solution. I used to fish along the Texas Gulf Coast and everything down there was rusted much worse than 50 miles inland where I grew up. Since the humidity and rain and such were pretty much the same, I'd take it does.
When down there, especially on hot, humid days, your skin just feels clammy and your equipment is clammy......yes.
