The MH44 EFI runs real good, needs some cold weather tuning.
I would not leave the O2 sensor on once tuning was done, pops the cost up about $400.
I would like to make something that bolts on where the Zenith was, tired of all the harnesses and mounting, it is just to much work to mount all that. I really liked the picture that was posted of the integral unit.
I would make the throttle bore bigger, and make a reducer that slides in to size it according to the engine, no sense having huge throttle plate on small engine. An original throttle plate would then be used so it matches the reducer bore.
I do think it is better to mount the fuel injector upwards in the manifold, this reduces the problem with cold manifolds and icing.
I would almost be tempted to mount the fuel pump in the tank.
I used the Microsquirt ECM, but I think I can do the required functionality with an Arduino, at 1/10 the cost. The tuner studio program I use has a build for the Arduino, so user interface would be the same.
My goal would be cut the cost from $1200 to $500 and include spark control.
