I use a 3pt side arm ditch mower on my 6300. Always a bit of a
The hydraulic hoses need to keep constantly pumping so the three remote levers for the arm / head will move. Usually no problem but the last couple times have been tough. No matter what I do the hoses pop out. Sometimes when I engage the hydraulic handle, sometimes when I engage the remote levers to move the arms/ head.
There are adjustments on the valve bank, it looks like. Piston and the other is a set of gears. What should it be for constant pumping. Also speed / flow control.
On the other side is the loader valve. Also a dial and when this is turned o loose loader control or three point control.
What should I have these dials set at to run this properly. Is my problem likely to be just the coupler barrels worm out or a pressure relief somewhere or something I'm overlooking completely.
Right now it seems to be running fine.
That is likly to change...
