Hello men, anybody out there know where I can get the stub shaft for a farmhand loader PTO driven pump. This is the short 540 pto shaft that slides into the back of the PTO pump so you can run an implement without pulling the pump. Some guys have said it is a short shaft with a bolt in the center that when tightened locks the shaft to the female 540 splines in the pump. I tried using the long PTO extenders that HH sells, they would work if they were hardened. Apparently the only manufacture that makes these shafts is in India and they do not harden them so they bend and twist like butter. They literally will twist when you are running an implement with no load. I have gone through 4 of them and they all twist and bend. A few other guys have posted the same problem. There is a long 15 inch Gresen pump adaptor shaft that will work if anyone has an old one that was hardened. Any help would be appreciated from the experts. Thank you in advance. Nick
