Wednesday "Extra" Pic
kcm.MN
Location
NW Minnesota
There was no picture when I clicked on these earlier . Lately been
having trouble with the picture loading but not making it to the second
page
I have one of those, but not that pretty. The trans axle of my 73 John Deere went bad, gears stripped. Had that Montgomery Ward sitting around doing nothin so it donated it's trans axle. Same thing except I had to change the gearshift lever and the two trumpets, which turned out to be a better rear end than the JD. The axles and hubs on the MW are built with longer axles and the hubs are fastened solid to the axles. Wheel hubs on the JD are splined and tend to wear right in the splines and wobble. So after buying a used set of hubs on Ebay to put on the shelf,I put the MW transaxle on the 73 112 John Deere. Then I got a Cub Cadet hydrostatic rear end and put it on the MW. The box on the Tructor is a well rusted Case dump trailer . It actually works quite well but I have no use for it. I think my son will wind up with it and I will wind up with his trailer.
