Jon Deere 4020 hydraulics question
allhat
New User
When running a batwing mower behind my 1966 4020 the wings of the mower will raise unexpectedly without anyone touching the remote lever. Where do I start to remedy this?
Hydraulic valve block (SCV) needs to be rebuilt, or at least re-set.
It's either under the hood, or back at the implement couplers, if you have a late model "side console" version.
'66 model JD 4020 scv is under hood. As Bob stated the poppet valves in control valve housing are leaking internally & need to be replaced & adjusted. Adjusting these valves CORRECTLY requires someone with experience in adjusting these complicated valves.
