(quoted from post at 04:17:41 07/13/18) That is the connector to attach the rear cultivator gang to the lift arms on an Essex tri-directional.
(quoted from post at 06:47:58 07/13/18)
I found TWO of these on the side of the road. I have asked a dozen people, and nobody knows what they are! They are 8" end-to-end, 1 3/4" wide (out side), and 1 3/8" wide (inside).
Any ideas?
(quoted from post at 13:23:56 07/13/18) It's going to be hard for me to describe but I think I may know what it is... We have several horse drawn implements that have a set-up on the end of the pole that allows you to attach the neck yolk with a "ramp and pin" system. Basically the hooks on the piece you have pictured hold the ring of the neck yolk against the tongue and the pin rests against a ramp on the pole end not allowing the hooks to let go of the ring. I tried to find a picture with a quick google search but no luck so far. I hope this makes sense its a weird setup to describe.
