oil pressure switch
Oil pressure switch for a 1971 Chevy Vega works well. That is the ne I use if I want to d the oil pressure switch to turn on the excite circuit
Using an oil pressure switch to excite the alternator is used on diesels where you can set it up so oil pressure comes up and that in turn switches on and that turns on the excite circuit. BTDT
Never tried a brake light switch on an engine.
Keep an eye on it, not sure if the diaphragm is compatible with oil. It may start leaking or stop switching.
