mf-35 oil pressure switch
noodles
New User
I mave a 1964 mf-35 with a Perkins diesel the oil pressure gauge switch which controls voltage to the fuel gauge is bad. I have checked and they don't make them anymore but have read I can use a new 1 for a mf- 135 diesel. is this correct? secondly in trying to remove my broken switch every connection is frozen even the using anti- rust penetrating liquid . I am afraid to force any of the connections because I don't want to break the working oil pressure gauge any tips on removing this existing switch? thanks Michael
Is it just a switch that turns on with oil pressure? If it is my Napa store has that kind on hand I've used them on a couple different
tractors. If you need a part number let me know I can find it out in the shop my email is open
The switches is was referring to are part numbers Napa OP6624 is a short version and OP6616 is a long body both function the same
