TractorLinks.com
Tractor Talk Discussion Forum
1800 OLIVER HYDRAULICS
CURLEA5149
07-12-2018 10:26:47
I BOUGHT AN 1800 OLIVER GAS FROM THE NEIGHBOR WITH A DUAL ACTION LOADER. WHEN I FINALLY GOT IT RUNNING THE LOADER STARTED RAISING AND THE LEVER WOULDN'T STOP IT, LIKE THE VALVE WAS STUCK. THE LEVER FOR THE BUCKET SEEMED TO WORK FINE. WHAT CAN I DO TO TRY AND FIX THIS. THE HYDRAULIC OIL IS MILKY SO I AM GOING TO DRAIN AND FLUSH THE SYSTEM FOR STARTERS.
CURLEA5149
07-13-2018 13:18:02
 Re: 1800 OLIVER HYDRAULICS in reply to CURLEA5149, 07-12-2018 10:26:47
Hydra-Lectric (rectangle levers) The loader kept moving even when the lever returned to neutral. I can move the lever both directions and it returns to neutral but doesn't stop the motion.
IanC
07-12-2018 12:49:05
From your post I'm assuming you are using the tractor remotes to run your loader. Do you have Hydra-Lectric stop (rectangular levers); or depth stop internal, or depth stop external (round levers)? Did the boom keep moving if you manually neutraled the lever, or just didn't the lever return to neutral when you let go?
