TractorLinks.com
Tractor Talk Discussion Forum
John Deere M Touch O Matic overflow?
FrozenNuts
07-12-2018 04:43:58
I have a JD- M that after a few cycles of the control lever spews oil out the filler cap under the seat. I have tried filling it to the test cock level with the unit in both full up and full down positions. It makes no difference. I have the service manual and it gives no troubleshooting info on this issue. I am looking for input from someone who has actually worked on an M TOM unit. Thank you.
M-MAN
07-12-2018 06:53:53
 Re: John Deere M Touch O Matic overflow? in reply to FrozenNuts, 07-12-2018 04:43:58
As was mentioned you are most likely pulling in air at one or all of the large suction line fittings. There are rubber seals in each one. You might get by with just tightening them all up but they are 70 years old now so you might want to think about replacing them. They aren't very expensive from Deere.
Another possibility is it's bypassing inside. Using the wrong oil will make it worse. I use 20 or 30 wt non detergent motor oil. It won't foam, works better and leaks less than anything you can put in there. It's in the motorcycle section at my local Advance auto parts.
DeltaRed
07-12-2018 06:40:06
Is the oil foamy? If so,it is sucking air somewhere.
boler76
07-12-2018 06:19:44
how is the engine oil level?
Mike M
07-12-2018 05:14:31
I wonder if it is sucking air in at one of the suction pipe fittings ? I had a 430 doing that.
