JustHayin
New User
I got a vermeer 605 super G and i cant get the gate to stay open or closed. only time it will stay opened or closed is with the gate lock on. I opened it and unhooked the lines from the tractor to make sure it wasnt the tractor or the ends. losing pressure somewhere with no leaks.
I have a MF 1440, which is a Vermeer 504G that does the same. If the 605 has the same hydraulic system, the dual relief valve is either defective or has something holding it open. Valve is mounted on hitch frame. My MF will bale if tractor valve is put in float after tail gate is shut.
