Deutz KH 500 Parts Diagram
Part Time Pete
I noticed that the gearbox input shaft on my Deutz/Fahr tedder has a lot of play, so I'm guessing I've got a bad bearing. Does anyone know where I could get a parts diagram? Our local Agco dealer is pretty good about getting parts, but I'd like to look at a diagram so I have a sort of road map before I tear in to it
Thanks
Pete
Pete ....... I think it's a good idea to post questions like yours here on Tractor Talk plus the specific forum which relates to whatever you are asking about. There is a lot more traffic here on Tractor Talk as compared to all the other less-visited ones so you're likely to find something in both places.
Thanks Ken - that helps a lot. The tedder does a decent job, but it's a little spindly. Hopefully I caught it before too much damage is done
Your probably right CH - it does get pulled by a tractor, so I guess I didn't break the rules
The weak points we found were the holes in the casting that the wing pivots mount on would egg out and let the wings lean back so the c couplers would skip. Very bad things would follow.
